hm hard for me as a novice. I ment 25mm/s inside and out as you said.
100% fan speed . lol tried 0.06, did not work at all this time. Almost nothing came out. re started a few times .. jam.
Edited by GuestA variety of things to try.
1. ensure your minimum layer time is at least 10 secs to give the printed layer time to cool before the next layer is deposited. It look small so if that is not possible to achieve you can either print 1 or 2 copies concurrently to increase the layer time. Alternatively you can give z-lift a go - both have their advantages and disadvantages.
2. Use the same print speed everywhere for the printing beyond layer 1. By that I mean the walls/perimeters external and internal, and infill. Changing speed changes changes extruder pressure which takes time to stabilise and can cause spots like you have on the vertical wall of the circular section.
3. Go slow, 25mm/s is good and go cool. Get those fans pumping out 100%; try and get that 195c down as low as possible. If that is normal pla I think you have headroom to go lower.
4. I am not sure what is causing that mess about halfway up the z-axis. maybe you got a stick and too much filament was extruded for that layer, not sure.
5. Actually as you have these problems I would drop to 20mm/s or even 15mm/s although I do not think I have ever gone to 15.
6. Try a different filament, sometimes that can all the difference.
7. Retraction; hmn I am no expert in that area. I got it working a couple of years ago and have never changed my settings since. No doubt someone else will have a view on that.
8. Fine test; yeah difficult aren't they. To me that says extruder too hot; maybe fans not 100%; minimum layer time less than 10 seconds; or just the impossible dream. Maybe worth trying a thinner layer to reduce the amount of filament being extruded
yellowshark 153
