tinkergnome 929
There is a plugin called SelectExtruder for legacy Cura...
Besides that, a simple "T0" (resp. "T1") at the beginning of the start-gcode should do the trick, if you slice it for a single extruder.
1
Dim3nsioneer 559
See https://github.com/Dim3nsioneer/Cura-Plugins/wiki/Select-Extruder-plugin
