@LePaul, if your HBK is giving you trouble, put tape on the glass, and set the temperature to 0. Then you can print like you are used to. Alternatively, try to use lower temperatures without tape(30-40C).
I believe you can power a 3wired fan with just + and -, atleast that's what I did during some testing
SandervG 1,521
Maybe this thread holds some answers for you![:)](//content.invisioncic.com/ultimake/emoticons/5a33abdf6d109_1f60acopy.png)
There are various threads to be found on our forums about dual fans on the Ultimaker Original.
I know @LePaul is also working on this now.
LePaul 330
Yes, but sadly I can't even get the ducts needed to print acceptably lately. The heated bed has made my life a bit more complicated lately!![:O](//content.invisioncic.com/ultimake/emoticons/5a33abe2058a2_1f631copy.png)
The link @SandervG gives is for an Ultimaker Oringinal + which has a metal shroud, just so you know. I have the UMO...no + I'm not sure what you have?
There's many threads here where there are concerns about the fans you use. I'm not a super experienced electronics guy but from what I can gather, the biggest issue is how many amps you draw. If you make sure the fans are low (as all are), you are fine.
There's also some comments about electronic noise, so when the next fan is added, it seems wise to keep those wires clear of the others (heat probe, etc).
Here's the model I've been trying to print http://www.thingiverse.com/thing:1268841
As for fans...2-wire is what comes on the UMO. Fans like this look like they would work. I am try to avoid cutting and splicing wires and looking for a Y adapter that would allow two 2-pin wire fans to plug into the one plug. I see 3 wire everywhere but not two. (If you find it, share!)
