Hi @SandervG,
thanks for the welcome.
I did not create a new material on the Ultimaker itself, since I found the steps needed to achieve that rather confusing . I exported the three standard materials to SD, then edited the file with Notepad++ and added a fourth one, and then imported it back in the printer.
SandervG 1,521
Hi @Mabe,
Thank you for your post, and welcome to the forum!![:)](//content.invisioncic.com/ultimake/emoticons/5a33abdf6d109_1f60acopy.png)
How did you create the material profile?
Did you create it on the Ultimaker first, then export it and import it later?
Thank you!
