@Cloakfiend : Thanks for the reply. I don't think I've ever seen a white bit in the feeder tube. I'll see if I can locate a description of that around here somewhere
Quick idea, maybe one of the ultimakers has a newer firmware? Latest firmware on um2 did change the amps to the feeder motor. That can change the force.
And if you use simplify3d as a slicer in the default UM2 setting the start G-code will change the motor current, which can also cause a difference.Quick idea, maybe one of the ultimakers has a newer firmware? Latest firmware on um2 did change the amps to the feeder motor. That can change the force.
Think the default is 1250 atm, S3D sets it to 1400, probably fine as long as you are not living in the hotter parts of the world where the extra heat from the feeder motor will be enough to be past onto the filament, causing melting/grinding.
Labern 775
The PT100's can be very different from one to another. This is the reason why it has been improved in the UM2+
If I remember correctly, Gr5 test's his before he sends them out. So either social a UM2+ sensors or 2 tested ones from Gr5 may help with consistency.
Not sure about the feeder. Maybe bowden tube? Alignment issue with heater block?
cloakfiend 996
I had similar issues, although i noticed minor upgrades on my current um2 to the older one i had, like a white bit in the feeder to guide the filament a touch better, a nozzle guard also (which irritated me) and i also got a spare hotend kit( bonus!) , which i needed when i broke my pt100 heat sensor. After replacing it with an offical stock replacement, i noticed my temps also change, it may have been the ob, but who knows. The feeder clicked like my old one, i read before about the diamond grips gripping better if the were positioned a certain way.
Edited by GuestLink to post
chrisw 70
Thanks @Labern. The Pt100 could definitely explain the 10C heat reading differences. I have a spare here, so I'll try mixing and matching to see if I have a similar pair. If not then I'll go to GR5
Regarding the feeder, maybe the bowden tubes are different. I'll try swapping those and see if the chirps follow the same tube to it's new home.
