I am sorry, I printed it with
- Layer height: 0.15
- Temperature 210 - bed : 60
- Shell thickness 0.8
- Bottom/top thickness 0.6
- Fill density 0%
- Print speed 40
- Nozzle size 0.4
- Travel Speed 200
- Bottom layer speed 15
- Minimum layer time 10
I think my z rod still OK because I stopped print the win turbine and printed something else, the other print look ok
I will try to print it with 0.2 layer height to see if there is a different
gr5 1,876
Don't make me read the thingiverse settings. What was your print speed, layer height, and temperature? I recommend 35mmsec, .2mm and 230C to start. If you are patient then 35mm/sec, .1mm and 210C. This should minimize underextrusion which is what your problem looks like.
HOWEVER
It could indeed be the Z. Many people have trouble with their Z such that it drops down too far suddenly. Usually it sticks for a layer or 2 and then drops 2 or 3 layers all at once. Usually it's the ball bearings. To test them, unscrew the Z ball bearings from the plate and slide them up and down by hand and check the feel. You don't want or need any oil on the Z rods. Clean any oil or dust off. If the Z bearings stick at all you need to remove them and clean them with WD40 and dry them well.
Alternatively put something heavy (about 1kg or 2 pounds) on the back of your Z stage. This also often helps.
