PT100 sensor resistance/temperature chart:
Edited by GuestHi Mick,
Do you still have the old nozzle block? If you have, -with the wires intact, try to use this one as it should be ok, hopefully.. Well, you can use a 100 ohm resistor to check that the temperature is reading approx. 0 deg. Celsius. You'll need another resistor at 180 ohm for a hot check, when connected to the board it will show approx. 212 deg. Celsius.
This is an easy way of checking your main boards response to a resistance equivalent to our PT100 (platinium sensor).
You have to be very careful when installing the termoistor, do not bend more than once on the wires going into the termistor block.. It is very easy to break, or to make a close break become an intermittent connection as you have.
Those resistor should be very easy to find at your place..
But I'll guess you just order a few of those PT100 as spare, -as they fail now and then.
Good luck.
Regards
Torgeir.
gr5 2,225
Do you have a multimeter? Measure the resistance of the temp sensor underneath the printer (while disconnected from the board). it should be around 108 ohms. Most likely somehow must have gotten damaged. You can get a new one from fbrc8.com (ultimaker original parts) or from my store at gr5.org/store/ (3rd party parts). I test every temp sensor at 260C because a while back many of them would open up around 200-240C and then start working again when they cooled. However your temp sensor sounds more seriously broken. They don't solder the sensor to the wiring inside because solder melts at these temperatures so instead they are crimped and metals expand at different rates when you heat them and so they can fail. Most fail very early on like yours. Once the temp sensor has survived a few prints it should survive for years.
Edited by GuestLink to post
