Nylon Printing Troubleshooting(warping+burning)
JDBW
Posted · Nylon Printing Troubleshooting(warping+burning)
Hi guys,
This is my first post on this forum and it's about some problems I stumbled across during a project for school.
We need to 3D-print a prothese socket with a nylon filament. 5a331aab756a3_Schermafdruk2016-04-0709_38_48.thumb.png.afe21a8717644216fca941625ea48925.png (cad model 2,5mm thickness)
We have tried to print it with the ultimaker 2 extended and various settings without succeeding.
The first print failed because the brim warped.
The second print failed because it used too much filament( we changed the cad model because it was bigger than expected). If we had enough filament it might succeeded.
The third print we used the same settings as the second print but a different filament(hestay). After a night of printing the brim let loose.
The fourth print burned so bad that we had to stop the printer.
All prints had in common that they had burn spots and that the brim let loose or warped.
Does anyone know how we can fix these troubleshootings?
Settings
Print 1:IMG_20160406_094553.thumb.jpg.1f32972cdc4562936e44f4fdf222c1f3.jpg
Taulman 910 2.85mm Alloy filament 245°C Extrusion Temperature 86°C Bed temperature
Support everywhere: 20° angle fill amount:+- 40% Brim
Print 2:IMG_20160404_094813.thumb.jpg.47a8ae757f78f72bc83bb54a76e51954.jpg
Taulman 910 2.85mm Alloy filament Alloy filament 245°C Extrusion Temperature 70°C Bed temperature
Support everywhere: 20° angle fill amount:+- 40% Brim + glue on platform
Print 3:IMG_20160404_092850.thumb.jpg.5e33bab9ae43e7962decfeb2dde4223d.jpg
Nylon filament transparant from Hestay
Same settings as print 2 but different filament and less fill amount of the support + glue on platform
Print 4:IMG_20160406_094553.thumb.jpg.7634330b30354131b3c668a4671b1eea.jpg
Same settings print 3 but a higher bedtemperature(100°C ) + glue on platform +covering front of the 3D printer
    you are using far too high a bed temperature
    Taulman recommends a bed temp. of only 45degC for Alloy 910
    I see you are right about that, but the strange thing is that the new filament we are using from hestay requires a bedtemperature between 90 and 110 degrees Celsius. But can the bed temperature have something to do with the burn spots higher in the product?
    the burning happens because nylon is very 'sticky', if you have little blobs from travel or retraction, they will stick to the nozzle and get caught, burn, in are deposited in another spot.
    Try to tape the (large) brim to the bed with ductape or so, right after the brim is finished. As long there is no air underneath the brim, it will hold. Don't push to hard on the bed when applying the tape, because yours layers will be deformed.
    Have you tried taulman bridge? I find it's a little easier to print and you can print it a bit cooler. Less burn spots, less steam making air bubbles. Nylon is definitely not an easy material to work with.
    Your burn spots are in a pattern - that must be where the Z axis moves. This implies you need to lower the temp a bit to get rid of those burn spots. I would try lowering it by 5C at a time while printing (from the TUNE menu) until you get a good compromise.
    If you print nylon too cold it can have HORRIBLE layer adhesion. If you are getting that then lower your fan. In fact you probably want the fan either off or at 30% maximum.
        • 4 replies
