Two manuals: Excellent bonding of PLA to glass + Improved atomic method to clean nozzle
Posted
(edited)
· Two manuals: Excellent bonding of PLA to glass + Improved atomic method to clean nozzle
I was having persistent problems with PLA warping and pulling off the print bed when printing large parts. I tried (individually, and in combinations):
- raising nozzle temperature
- raising print bed temperature
- slow first print layer
- thicker first print layer
- disable fans for several layers
- glue stick
- releveling print bed
- clean print bed with rubbing alcohol
But I couldn't get a perfect result without any warping. Until now. Geert's salt method works amazing. Using it, I can drop the nozzle and print bed temperatures back to normal - which also improves print quality. I used it on a 9 hour print (that I had previously repeatedly aborted and restarted due to warping), and it printed flawlessly.
Thanks Geert.
1
Eraser 31
- glue stick
Thanks Geert.
Edited by GuestLink to post
