Ultimaker resellers, Igus (they sell also for common users) and Misumi (they only sell to business).
I got mines from misumi and igus (and ultimaker ofc). This part numbers are for shafts for umo+ or um2.. I can't remember XD
The part numbers for Misumi are:
PSFJ6-267 (head 6mm shafts)
PSFJ12-339 (z 12mm shafts)
PSFJ8-348 (y? 8mm shafts)
PSFJ8-337 (x? 8mm shafts)
PSFJ it's the material and kind of shaft. the next number it's the diameter then - then the length in mm
This are the part numbers for Igus linear shafts that I got.
SWMH-08 2,00 15,34 CF53-Welle, 8mm, h7, gehärtet, L=337 mm
SWMH-08 2,00 15,34 CF53-Welle, 8mm, h7, gehärtet, L=348 mm
SWMH-06 2,00 15,34 steel shaft, 8mm h7 hard- L=267 mm
Igus it's cheaper them misumi, but as far as my printers work, both are quite perfect for the job.
Remember that I have just copy/paste the info. You need to go to the bom and check the size of each shaft and diameter. Also I'm no expert in shafts (by a mile) so if you want to be sure sure, just buy it to ultimaker.
1
Labern 772
You can contact your nearest UM Reseller and get any of the parts you require from them.
