Thanks for your quick reply
I was reading up on the warranty information and it says it's void if I try to repair unless it's "official" ultimaker support advice somehow. I see you're a moderator on this forum - does that mean I can follow your advice and not void my warranty?
gr5 2,072
This has never happened to me (on purpose) but is very easy to fix. Permanently.
Basically there are pulleys and plastic spacers near the 4 corners of the machine - 8 of them. They keep the axle from sliding out of the machine (but don't prevent it sliding inward). The side where it slid out - the pulley there has a set screw which was not tight enough.
Just push the axle back into the hole where it belongs and line it up so it is all the way in and won't go any further, then slide the pulley nearest the "fell out hole" against the outer wall and tighten the hell out of that set screw. Those are 2mm hex set screws. Do not use the wrong size tool. If you use an L shaped tool you should be tightening enough for it to hurt your fingers. tight enough to actually twist the tool slightly where you are scared it will break. Don't use pliers or other torque increasing tools as then you might break it, but very very tight.
You can add lock tite but I never did and my screws on all my printers have held for years now.
As far as the center/thinner rods that go through the head - they can just snap back into the side blocks - you have to push with a certain amount of force - enough to bend and damage the thicker rods (or those thinner rods) so brace yourself against the frame and not against the rod. Use your other hand to hold the sliding block so it doesn't tilt and squeeze/snap it back in.
gr5 2,072
>The design of this holder looks a bit weird to me since the metal axle is not fully enclosed by the plastic
True but then it would be hard to manufacture.
