Most likely you are levelled a bit too high off the glass. Try turning the 3 leveling knobs a full turn counter clockwise while printing your next part to see if that helps.
Thanks, Ill give it a try.
Did you change it out for the same nozzle again, or did you install an Olsson block? Can you provide any photos if you're still having problems?
gr5 1,843
