Thanks for the reply, any ideas as to what might be causing it or how to diagnose or prevent it.
zerspaner_gerd 383
Is indeed from the Cura, and proceed to in 2 axes. (X and / or Y and Z)
You can using this sound reproduction in which you gcode this.
M107G28G0 Y100.0 X50.0 Z100. F9000G1 X105.0 Z100.3 F6000M25 ;Stop reading from this point on.
- 5 months later...
what did you do? a diffrent version of cura?
Again - I think it's fine. Not a problem as far as I can see and hear.
gr5 2,230
Doesn't sound serious to me. It seems like it happens on travel moves only and only during layer change. As though it's doing the Z and X move at the same time which is not how it normally works. Anyway I've heard much worse sounds. I don't think anything is getting damaged.
