Yes. Make sure brim and skirt lines are set to zero. Even then it might fail. I think cura creates 2 rectangles - one longer in X that goes between the clips. And one longer Y that goes between the clips the other way. Your part is outside both of those rectangles yet still does not touch the clips. So this is kind of a bug or limitation of Cura. You can lie to cura and tell it the bed is 250mm by 250mm and then place the part as close to 0,0 as possible (front left corner). I haven't tried this but I suspect it will work.
- 2 weeks later...
I want to thank you for your quick answers and excuse me for my late reply.
I have tried it with the Cura beta 2.x.x version and the part could be printed. But I will try what you suggested, because I think the Cura 15.x.x version works much better. (I don't know the exact versions).
Depending on what Cura do you use, the buildplate volume isn't the same.
For example I know that 15.04.5 buildplate for UM2 is 205x205 and 15.04.6 is around 203x203
Nicolinux 287
I think Cura wants to print a skirt around the object and depending on its settings it would be outside the printable area. Check the expert settings (cmd + e on the Mac).
