I need people to check
Posted · I need people to check
Hiya every one,
I need to ask the community a favour.
Those with UM2+ and that have upgraded the firmware using latest cura,
Can you check the material profile for ABS and let me know the bed temp?
Can you also check the max temperature you can manually set the bed to in the advanced maintanance menu?
Reason I'm asking is that mine is Max'd out at 100 degrees. Nothing I do allows me to set it to 110 for my prints.
My material profile states 90
I've printed with ABS for 3 years and never printed below 110 as the prints start to peel of the bed.
The support team are looking into it but I am unique in this problem.
Many thanks in advance
Becky
    Hi Becky,
    I can verify that with the UM2+ firmware, my ABS material profile is identical to yours.
    I also cannot raise the bed temperature over 100C.
    I rarely ever print in ABS so I would never have known this was problematic.
    Posted (edited) · I need people to check
    Hiya,
    I had an answer from UM,
    they have limited the bed temp to 100 degrees intentionally.
    if you need to go higher then revert back to the previous cura version.
    kiind regards
    Becky
    If you find out which version supports 110C, let us know please. You can see the version number on the printer's display - it's in the advanced menu somewhere.
    I would try this version -- I don't know if it goes to 110C but it might:
    https://github.com/TinkerGnome/Ultimaker2Marlin/releases
    I just used Cura 15.4.5 to load the default firmware and that was it. Cura software comes with the firmware in a folder on your PC, It doesn't connect online for the latest version like some other slicers.
    Regards
    Becky
        • 24 replies
