I am not sure if it is a good idea to add laser cutting/engraving stuff to a machine that is not designed for it.
You would first need to completely cover the machine with a laser-safe enclosure, or else it may be cutting/engraving your skin and eyes too. A laser that can cut through metal, surely can cut through skin, light sensitive eye-cells and even skulls.
And then the rays bouncing around still may be cutting/engraving the inside of the machine: the print head, rods, belts, glass plate, aluminum heated bed, side panels,...
While I agree that you shouldn't look directly at it or stick your fingers under the laser, those units do need to be focused to actually cut anything... So I wouldn't worry too much about damaging the machine... You do need to be careful with your eyes though.
geert_2 556
