A high performance DC motor is alot smaller and lighter than a stepper of equivalent
shaft power output. The reason this is interesting for me, is that I am considering
putting the motors on the printhead.
C.
C.
Couldn't you just go with a smaller stepper with a larger gear ratio to make up for the lack of torque? Seems it would be much easier to implement.
Yes I am looking at some very small steppers with a gear reduction of about 50:1
I have some some calculations on the extrusion forces, and also some tests.
However if you used a miniature DC gearmotor its possible to have even better power density.
But if its a massive pain to do, I might just stick with trying the 50:1 stepper motor reduction.
It seems like the electronics are all set up for steppers, so I might be stuck with that.
C.
Hi! I would like to share this great online resource for anyone seeking a dc-gearmotor: http://www.directindustry.com/industrial-manufacturer/dc-gearmotor-65199.html
tomnagel 98
I'm always in for improvements, but why would a DC extruder drive be an improvement?
You mention weight, but since the extruder is mounted on the frame, what drawback do you see for 500g extra?
On top of that, an accurate DC drive with encoder feedback requires quite some processor resources (high controller loop freqency (500Hz?)).
Therefore, I think the choice for steppers is a good one.
