Hiya,
when you say blobs, is the it's dripping out of the nozzle and going onto your print, it leaves a blob before moving of the the next part or a blob at the start of the next part.
if it's the latter then in the extra retraction distance enter a negative value.
if it's the first one then I think your temp is still to high or increase the retraction.
the middle one asks for faster retraction or tick the retract during wipe.
hope this helps
Becky
1
gr5 2,331
Try to make all the speeds identical. This can reduce stringing quite a bit. I don't know S3D but I assume 3600 means 60mm/sec and .6 means 36mm/sec for outer shell and .8 means 48mm/sec for infill and support. Make them all 35mm/sec (slower and equal). At 35mm/sec you get much less pressure in the head so less leaking.
Just experiment. If that works try increasing the speed in the TUNE menu and take notes. Then set it to the fastest speed with no stringing but trying increasing infill speed. Take notes.
Edited by GuestLink to post
