jittery inner wall
dgrogandesign
Posted · jittery inner wall
Hi folks.
I have noticed that my printer often does this strange thing where it "vibrates" around the inner wall. this is more time consuming that simply tracing around the edge as i would expect it to do. ive taken a look at the slices and think that the images reveal why its doing it.
the first one has a nice clean inner trace and the second one is all mudded up. does anyone know why this is happening?
Any help would be much appreciated.
Dan
5a331e2226a57_ScreenShot2016-06-14at10_29_34.thumb.png.d78ba0cdd1fee78dc606f5cb4c31daa0.png
5a331e223b8ee_ScreenShot2016-06-14at10_29_30.thumb.png.127b2a86ec0d445a711f069f5be8de49.png
Cura profile string:
;CURA_PROFILE_STRING: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
[/media]
    Please give us the profile you use by saving it in ".ini." file.
    Then, we would be able to open it and check it out !
    hi this is the copied text from the .ini file. is this what you require?
    thanks.
    ps. i noticed that the inner line clears up when i revert back to a single instance of the model(the screen shot was taken when there were two copies )
    whether this will translate onto the print ive yet to find out but whatever the result its strange....
    [profile]
    layer_height = 0.2
    wall_thickness = 0.8
    retraction_enable = True
    solid_layer_thickness = 1
    fill_density = 20
    print_speed = 70
    print_temperature = 240
    print_temperature2 = 0
    print_temperature3 = 0
    print_temperature4 = 0
    print_temperature5 = 0
    print_bed_temperature = 90
    support = None
    platform_adhesion = Brim
    support_dual_extrusion = Both
    wipe_tower = False
    wipe_tower_volume = 15
    ooze_shield = False
    filament_diameter = 1.75
    filament_diameter2 = 0
    filament_diameter3 = 0
    filament_diameter4 = 0
    filament_diameter5 = 0
    filament_flow = 100.0
    nozzle_size = 0.4
    retraction_speed = 60
    retraction_amount = 4.5
    retraction_dual_amount = 16.5
    retraction_min_travel = 1.5
    retraction_combing = All
    retraction_minimal_extrusion = 0.02
    retraction_hop = 0.075
    bottom_thickness = 0.2
    layer0_width_factor = 150
    object_sink = 0.0
    overlap_dual = 0.15
    travel_speed = 150.0
    bottom_layer_speed = 20
    infill_speed = 0.0
    solidarea_speed = 0.0
    inset0_speed = 0.0
    insetx_speed = 0.0
    cool_min_layer_time = 5
    fan_enabled = False
    skirt_line_count = 2
    skirt_gap = 3.0
    skirt_minimal_length = 150.0
    fan_full_height = 0.5
    fan_speed = 100
    fan_speed_max = 100
    cool_min_feedrate = 10
    cool_head_lift = False
    solid_top = True
    solid_bottom = True
    fill_overlap = 15
    perimeter_before_infill = False
    support_type = Lines
    support_angle = 60
    support_fill_rate = 15
    support_xy_distance = 0.7
    support_z_distance = 0.15
    spiralize = False
    simple_mode = False
    brim_line_count = 20
    raft_margin = 5.0
    raft_line_spacing = 3.0
    raft_base_thickness = 0.3
    raft_base_linewidth = 1.0
    raft_interface_thickness = 0.27
    raft_interface_linewidth = 0.4
    raft_airgap_all = 0.0
    raft_airgap = 0.22
    raft_surface_layers = 2
    raft_surface_thickness = 0.27
    raft_surface_linewidth = 0.4
    fix_horrible_union_all_type_a = False
    fix_horrible_union_all_type_b = False
    fix_horrible_use_open_bits = False
    fix_horrible_extensive_stitching = False
    plugin_config = (lp1
    object_center_x = -1
    object_center_y = -1
    [alterations]
    start.gcode = ;Sliced at: {day} {date} {time}
    ;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
    ;Print time: {print_time}
    ;Filament used: {filament_amount}m {filament_weight}g
    ;Filament cost: {filament_cost}
    ;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
    ;M109 S{print_temperature} ;Uncomment to add your own temperature line
    G21 ;metric values
    G90 ;absolute positioning
    M82 ;set extruder to absolute mode
    M107 ;start with the fan off
    G28 X0 Y0 ;move X/Y to min endstops
    G28 Z0 ;move Z to min endstops
    G1 Z15.0 F{travel_speed} ;move the platform down 15mm
    G1 F200 E3 ;extrude 3mm of feed stock
    G1 F{travel_speed}
    ;Put printing message on LCD screen
    M117 Printing...
    end.gcode = ;End GCode
    M104 S0 ;extruder heater off
    M140 S0 ;heated bed heater off (if you have it)
    G91 ;relative positioning
    G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
    G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
    G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
    M84 ;steppers off
    M106 S0 ;turn fan off
    ;{profile_string}
    start2.gcode = ;Sliced at: {day} {date} {time}
    ;M104 S{print_temperature} ;Uncomment to add your own temperature line
    ;M109 T1 S{print_temperature2} ;Uncomment to add your own temperature line
    ;M109 T0 S{print_temperature} ;Uncomment to add your own temperature line
    G21 ;metric values
    T1 ;Switch to the 2nd extruder
    G1 F200 E10 ;extrude 10mm of feed stock
    G1 F200 E-{retraction_dual_amount}
    T0 ;Switch to the first extruder
    G1 F{travel_speed}
    M117 Printing...
    end2.gcode = ;End GCode
    M104 T0 S0 ;extruder heater off
    M104 T1 S0 ;extruder heater off
    M84 ;steppers off
    ;{profile_string}
    start3.gcode = ;Sliced at: {day} {date} {time}
    G21 ;metric values
    T2 ;Switch to the 3rd extruder
    G1 F{travel_speed}
    M117 Printing...
    end3.gcode = ;End GCode
    M104 T2 S0 ;extruder heater off
    M84 ;steppers off
    ;{profile_string}
    start4.gcode = ;Sliced at: {day} {date} {time}
    ;M109 T2 S{print_temperature2} ;Uncomment to add your own temperature line
    G21 ;metric values
    T3 ;Switch to the 4th extruder
    G1 F{travel_speed}
    M117 Printing...
    end4.gcode = ;End GCode
    M104 T3 S0 ;extruder heater off
    M84 ;steppers off
    ;{profile_string}
    support_start.gcode =
    support_end.gcode =
    cool_start.gcode =
    cool_end.gcode =
    replace.csv =
    preswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
    ;This code is added before the T(n)
    postswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
    ;This code is added after the T(n)
    Posted (edited) · jittery inner wall
    I believe this is caused by the top/bottom thickness. If you set it to 0, you will notice this goes away. (but obviously that's not really an option unless you want an open top, but try to slice it with that setting to 0 to see if it's what's affecting it).
    There is a reason for this though, it places material under the next layer's inner perimeter. While annoying, it serves quite an important function IMO. On larger details it will be lines which makes sense, but if you have a gradually sloping side, it will appear to 'vibrate' because the lines are small.
    Anywho, that's what I think it is, and if your object looks good it's working as intended. :D
    *edit, I just had another thought after I posted... It could also be that your object has way too many polygons.
    I am using ABS yes.
    valcrow - I tried on your suggestion to turn off the top/ bottom thickness but this did not help. I have also tried reducing the polygon count to see if that helps. It didn't. Ive included a screenshot of my object in wireframe mode. The troublesome areas seem to be the fingers which seem to have a cleaner mesh but they are square polygons. could this be the problem?
    Also included more cura screenshots.
    Thanks.
    5a331e3a1bc2a_ScreenShot2016-06-16at14_05_14.thumb.png.125a7881cd450c7021a51fb74f91590c.png
    5a331e3934b06_ScreenShot2016-06-16at14_07_22.thumb.png.bebf359e8a6c037fbc597d0b2c79903c.png
    5a331e3a42817_ScreenShot2016-06-16at14_07_28.thumb.png.538093bca4e8f1f73b244a15a986c936.png
    I still have this issue in 4.8. Inner walls are not continuous curves. This was supposedly fixed in 4.8 but still persists, even with default profiles. The problem is visible in the g-code, so it is not the fault of the printer. Printer jitters around the inner walls, causing vibration and print defects.
    If you can - post an  STL / 3mf file.  I've never seen those jittery moves before and I don't think it's any Cura settings that do that.  Cura may be confused over something in the model.
        • 24 replies
