Need round, smooth finish on cylinder
Tony
Posted (edited) · Need round, smooth finish on cylinder
Hey guys,
Recently bought an Ultimaker 2 Extended + and am still pretty new to this stuff. When printing a cylinder, it creates a hex like pattern with about 24 flat faces around, however it needs to be a smooth surface.  This is only a prototype and durability isn't of an issue.  I am using Ultimaker PLA.  The drawing came from AutoCad then Cura. It is going to be used as a demonstration for a product which has a smooth, round finish.  I printed the UM2 Cylinder that came on the SD card with the printer and it was much smoother around. Is this due to the wall thickness?
Was wondering if there are any settings to change to achieve this desired finish.  Again, I am new to this and would appreciate any help.
Thanks
My print
UM2 Cylinder print
    Posted · Need round, smooth finish on cylinder
    This is a problem with the model. I'm not familiar with AutoCAD but there should be an option somewhere that dictates how detailed the export of the model should be. In this case it is representing a circle with 24 line segments, there should be an option somewhere to increase this number to get a higher resolution on the exported part.
        • 21 replies
