Exp1/2 are the ones that the board uses to connect to the ulticontroller.
Checking the github of the ulticontroller there's info about the connector part number
TE connectivity 1-1634689-0
Wow it even has the rs-components number:
http://es.rs-online.com/web/cpd/4738349/?searchTerm=473-8349
http://docs-europe.electrocomponents.com/webdocs/0649/0900766b80649771.pdf
gr5 2,192
There are definitely quite a few extra signals. I'm not sure which ones are extra but the ones on EXP2 look more likely as some of the ones on EXP1 might be used dual purpose. So double check that. That connector you link to is a .1 inch spacing which is almost certainly correct.
So I can't actually verify anything but I think you are on the right track.
Edit: oops - exp1 and exp2 I guess are for the display and sdcard reader. But I'm sure there are more signals available somewhere.
Edited by GuestLink to post
