I find the threads in free fusion360 easy to use...
This is not hard to do. What cad software are you using? You want relatively large threads like this part:
http://www.thingiverse.com/thing:925556
I'm using sketchup 2016 win 10 64bit.
I will try it tonight.
Just as a sidenote: Fine threads are possible too. For a C-Mount lens i have printed a thread with 25.4mm diameter and ~0.75mm pitch at 0.08mm layer height and it worked better than the c-mount extension adapters made of aluminium that I bought from ebay. I only added 0.2mm to the diameter, which seems necessary for all vertical holes.
hi guys. i have tried fusion360.[print=
Upload your photo by drag & drop
Choose a file
Main image
Enter your print details
Used in:AerospaceArchitectureArtAutomotiveEngineeringFablabsFashionHumanitarian aidJewelryManufacturingMedicineProduct designResearchPrimary educationSecondary educationUniversityDIY, hobbies and home
Used as:Concept modelsFunctional prototypesEnd-use partsTools, jigs and fixturesMolds and castingVisualization aidsLessons
Layer resolution:20 micron21-40 micron41-60 micron61-80 micron81-100 micron101-120 micron121-150 micron151-200 micron201-250 micron251-300 micron
3D printer:Ultimaker 2+Ultimaker 2 Extended+Ultimaker 2Ultimaker 2 ExtendedUltimaker 2 GoUltimaker Original+Ultimaker OriginalOther
Print time:< 1 hour1-2 hours2-4 hours4-6 hours6-8 hours8-12 hours12-18 hours18-24 hours24-48 hours> 48 hours
Color:BlackSilverWhiteTranslucentYellowOrangeRedPurpleMagentaPinkBlueGreenBronzeGoldBrownGlow in the DarkSpecials (wood, copper, etc.)Other
Nozzle diameter:0.25 mm0.40 mm0.60 mm0.80 mmOther
Material:PLAPLA FlexibleABSCPEPETNylonWoodCopperBronzeBambooCarbonIronOther
Optional details
Post print
Follow and receive reply notifications
$(function() {
var printUploader = new Uploader();
printUploader.init();
$('#print-popup').find('form').parsley();
if (util.applyUniform) {
util.applyUniform();
][/print]
do u think that it will join together?
Nailed it! Thanks for all your help guys!
print_printTime" name="print[printTime]" required="required">Print time:< 1 hour1-2 hours2-4 hours4-6 hours6-8 hours8-12 hours
What?
Screen shot or photo of your part please?
gr5 2,330
