Many of the settings are saved at the end of the gcode.
Also, you can edit the file name in Cura 2.1.x, just click on it.
sure you can, but the point of having it configurable is you set it up once to your liking and forget about it..... I fe want the nozzle size in the filename, but you might have a different need...Many of the settings are saved at the end of the gcode.
nallath 1,065
Next version already has it. No need to get all exited.
The saving thing that you found is a bug, which is also fixed.
ultiarjan 1,215
could be nice to have a more configurable naming. f.e. when you only have one machine the machine name is useless, but you may like the nozzle size or layer height in your gcode file naming....
