the thing that went wrong in your case was the second layer after the raft, which in this case might be replaced by a brim instead (rafts are not used very often). The problems are the round beams with a rim around, the rim touching the build plate and the beams floating. Did you check the layers view to see if there was any material underneath the beams?
What also helps in these first layers is to go slower until the base is there, then go to normal speed.
gr5 1,841
The leveling procedure has made you level the bed too far from the nozzle. Just turn the 3 knobs counter clockwise (as seen from below) a half turn and try again. Your part isn't sticking to the glass because the filament isn't squished enough. You want like the blue print below.
