Sorry, here you go. Pictures below are the print. You can see the extra lines it's laying down, obviously like it's trying to "support" the hook/loop. It did this when we had support structure 'on.' But turning off support structure is resulting in almost the same print. You can also see from the side view the hook/loop is completely filled solid and it should be hollow, and the curve is gentle enough the Ultimaker should be able to build this without support.
Also below is the STL file generating the print.
IRobertI 516
Some pictures of the problem print and the actual model will help greatly in figuring out what's going wrong.
