Depends on the age of the printer. The older ones the blue clip didn't really do much but the newer ones it holds the white tube clamp tight in the up position so it wont come loose.
There are ones you can print that are a bit higher on youmagine that you could use which hold the white tube clamp up.
1
Labern 772
Is it a ultimaker 2+ or 2?
Sounds like UM2, so With the power of you can just pull the filament out. It's hard to pull but will come out. Then you can remove the blue clip from the Bowden tube clamp on top of the feeder, push the white bit down and pull the tube out. You can do this on both ends and push the broken bit out with some filament.
Before running again you should sharpen the end of the filament like a pencil which will help feed in without getting caught.
If it's a 2+ you move the leaver then pull the filament out.
Edited by GuestLink to post
IRobertI 497
Also, you should be clicking the menu button after the filament exits the feeder. It will then speed up significantly to feed most of the way to the head before slowing down again.
And if the filament is breaking inside the tube that might be an indication that you have a spool of filament from an old batch that was bad.
iraholston 0
Thanks! I have a bad spool of filament, it is very brittle! I have had a number of successful prints once I cleared the bad, brittle filament.
Are the little blue clips "optional", they do not seem to stay on or do very much anyway?
Trying some new ABS filament now. Really excited, I teach high school and this is a big step up from our New Matter 3d printer.
