Looks like you have problem with layer shifting which is most often caused by the pulleys on the motor shafts being loose:
http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide#shifted
Also, what is going on with your bed? It looks like a horror show, is that a ton of glue or what is it?
Thank you for the suggestion. My printer had the problem of heating up of motors. I changed the current settings from 1300 mA to 1000 mA. Now its working fine.
I want to know does reducing the current to such extent can damage the motors in long run?
How much low current settings are acceptable by the motors?
Is there any way to cool these motors by attaching heatsink and fans to them?
IRobertI 514
