Hi Labern,
Thanks for your insights! Wisdom from the master!
So, versus the original, yours is better enough to be worth it. Versus the upgrade, the improvement would be marginal, and metal is more reliable.
I was considering printing yours in polycarbonate, like I did last time, if it was worth it, since it worked so well. But if there is not much improvement, and I plan on printing more in polycarbonate for other stuff, then sticking with the metal one might be the wiser idea.
Thanks very much for sharing! And thanks for the shroud!
If anyone else has additional insights, I would love to hear them too.
Labern 772
So the Original UM2 Fan shroud had 0.6m/s air flow
the new one has 2.2m/s air flow
mine has 2.5m/s air flow
So percentage wise there is not much difference between mine and the new one. Mine is directed more where it needs to be and more even though.
I still like and use the metal fan shroud as you can print at 300deg all day every day and not worry about it. It also helps me sleep at night
Although cooling is important and can greatly help print performance, I think there are a lot more areas that can have a greater improvement on overall print quality.
