I just think that when your printer was assembled they forgot to tight hard one of the pulleys (check all of them if possible including the one on the motor). After all it's tight it will print just fantastic.
Once I also had this issue because I dropped a bit of oil on one belt, cleaned it with alcohol and never got the problem again.
Read the troubleshooting guide. It covers and explains how to fix it quite fast.
Ofc this doesn't have to happen on all prints, but clearly somethings it's slipping on that print and since it's only on the X, I would check the x motor (right bottom corner) pulley screw and the corresponding shafts/rods pulley screws.
Edited by Guest-
1
neotko 1,417
Your printer seems to be shifting layers.
http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide#shifted
woofguy 1
Neotko,
Could this really be the issue even though other prints are fine?
