Hello! Thank you for responding. Sorry the other shots weren't very detailed. Hopefully these are better. The brill on the underside at the extreme ends is not glass smooth, and at the worst part, the print itself started to lift off the plate. Interestingly, the underside of the print everywhere else looks great, but when I tried to print without brill (pla 60c, 210c) the print lifted off the plate and warped in one area.
What appears to be happening is that after a couple rings of brill, the nozzle starts to smudge the lines and they become increasingly ragged. When it gets to printing the bottom layer of the model, it evens out...
Penny for your thoughts!
SandervG 1,518
Hi @Eric-Rae,
thank you for your post! Could you perhaps upload some more pictures of your brim that show a little bit more of it? For example, from the top view?
How does the bottom of your print look like? Is it flat and glossy like a mirror?
Have you made sure to level the bed to your best accuracy after the upgrade?
