This is especially for the impatient
My nozzle usually takes appr. 2 minutes to heat up for ABS, think of a small print with about 5 min printtime. This saves you almost 25% of printing time (in fact the time the nozzle needs to heat up).
Most important in your post are the words "and then" it heats the nozzle, this is done in parallel with the plugin.
Edited by Guestlast chapter added
Dim3nsioneer 528
What material do you need such a behavior for? Heating up the nozzle should take much less time than heating up the bed. Cura heats the bed up to a certain level and then starts to heat the nozzle in parallel. On my UM2 with 35W heater the two are pretty well synchronized.
Please be also aware that legacy Cura you wrote the plugin for is not supported anymore by Ultimaker.
Edited by GuestLink to post
