tinkergnome 929
The bad news is: there's no existing dual firmware for the UM2+ that will fit your needs. But that's a fact you already know...
The builder from @amedee generates firmware images for the Ultimaker Original, those are not usable for an UM2. I'm not aware of a firmware builder for the UM2 (and UltiCreatr is also a completely different thingy....)
I don't know your expectations or your technical background. Reading this sentence: "use the old Feeder and install it as Dual Extrusion"- well, it's not that easy...
If you want to make some experiments with this, you have to compile a custom firmware for yourself. The sources of the UM2+ firmware are available on GitHub.
...or just start with the dual firmware for the (standard) UM2, adjust the steps/mm and...
...swap the cables...
2
neotko 1,418
You should contact Creatr that is the one that sells that unofficial kit. So far I heard bad stuff about it and they have not post back. For example seems that with that kit you can't print with one hotend and bed, so blue tape all the way.
Anyway you should contact them or use their firmware to trry to make it work.
Edited by GuestLink to post
tinkergnome 929
Sorry, but your compilation seems a bit confusing to me...
Hinz 0
PRinter: Ultimaker 2
Upgrades: Ultimaker Extrusion Upgrade kit (which makes it Ultimaker 2+)
Setup: both, the old Extrusion set and the new Upgrade kits are installed at the moment (to make it dual extrusion)
we couldnt find an appropriate firmware that supports dual extrusion then the UltiCreatr firmware
custom firmware builder: https://bultimaker.bulles.eu/
