The power cables are not loose. In the meantime it stops every time a print job starts after a second.
Well, now i did a factory reset and it seems to work again.... At least it starts printing now. I will know more in two hours whe the print job is finished hopefully.
I heard a rumor that UM switched power supply vendors maybe and that the new supplies are not as reliable. Not sure if this is true.
Not true, they are shipping the exact same mean well power supplies as always...
Edited by GuestYou both right and wrong
Ultimaker didn't change the model, but meanwell the guys that make the PSU umo+/um2 uses, declared not long ago the old model obsolete and released other that technically is the same but maybe ia different?
Same same but different.
Old model: gs220a24-r7b
Newest: gst220a24-r7b
gr5 2,334
Usually it's a loose power cable. It is supposed to snap in and if you pull on it then it should not come out. If your power cable doesn't fall out easily then alternatively it's probably a bad power supply. I know they are expensive like €100 but it may be your only option. Although if it is only a month old maybe you can get a new one for free. Talk to your support people and refer to this thread.
