Hi Neotko
It is definitely the UM2 with no upgrades. IN the first instance, can you explain what the statistics mean?
What does this tell you/?
Hi Neotko
Pretty self explanatory. Machine was on for: 1913 hours and 21 minutes. It was actually printing for 1001 hours and 23 minutes and used approx. 1037 Meters of filament.
What I would certainly do, is have a small object printed in front of my eyes. Then it is obvious if it works well or not.
Maybe also print a big low object (e.g. 200mm x 200mm x 0.5mm) that almost fills the build plate, then you see if all axes move fine.
Carefully watch and listen.
Also ask about the PTFE couplers in the nozzle (the white cylinders): have they been replaced recently? If not, they will be worn out and you will need to replace them.
neotko 1,415
I think is better if you do the opposite. Make photos of the printer, hotend, front, back, bottom, sticker of the printer with serial, and then we can give you some info about what we can see. There's been some upgrades for um2 so it might have them or not. There's a UM2, then they released a UM2 with option for the users to install the Olsson block and then there was the UM2+ and the UM2+ upgrade kit for UM2. So, I think is better if you upload photos and we give you our modest opinion.
