I'm guessing you have bad layer adhesion. Are the side fans on? You want them on the absolute minimum fan speed for ABS. Somewhere around 20%? You want them to spin and if you go too low they won't spin so figure out the absolute minimum for your fans and then increase by a few %.
The problem (my guess in this case - picture wasn't super helpful and looks fine) is that ABS needs to be much hotter when the second layer comes down or the new layer doesn't melt the layer below and they don't bond well.
Found the problem, Print Bed was very slightly out of level
re-leveled the bed now prints raft OK.
I print without the fans on, otherwise the print will not stick.
Thanks,
Phil
Bottom layer fans off is the default in cura. But you need it for pla overhangs (for abs you want the tiniest bit of fan for overhangs - so I like around 20% fan - assuming 20% is enough to get your fan to spin - for some printers maybe not).
IRobertI 496
If you could take a couple of well lit pictures of the print, that would help a lot in figuring out what's going wrong.
