Dim3nsioneer 528
What about Polycaprolacton?
Isn't your PLA already destroyed beyond being usefull at 130°C? At that temp, my PLA is usually shrinking into a ball or leaking away...
And what if your customers would use alcohols or etox to sterilise things? (Although I wouldn't recommend using etox: it is highly explosive, causes severe chemical burns, and causes cancer.)
Machinable Wax maybe?
http://machinablewax.com/product.php?product=52
"Extrusion temperature = 135°C-150°C"
I already tried the PLA in our sterilizer and it was just deforming a little bit, not that much that I want to do.
Next week I'm gonna try out some materials and will give a short report about the material and the melting behaviour at 134 °C.
Well there is Cx5 sculptable filament by Adam Beane.
And there is instamorph (PCL) filament by eSun: http://www.esun3d.net/Products/eMorph
That melts at 80-110C.
Edited by GuestWell there is Cx5 sculptable filament by Adam Beane.
I now tried two filaments of igus.
The first I tried was the iglidur I150 which produced a nice block for testing it in the autoclave. The second filament was iglidur J260 which stucked in the nozzle so I cant even test the behaviour in the autoclave.
I150 melted pretty well during the reprocessing, even more than the PLA i tried before.
I will receive some colorFabb samples this week so I will give you as soon as possible an update. Maybe I get the chance to also try the Cx5 or PCL.
Benedikt1992 0
I know that PLA is deforming at 134 °C because I tried it.
But what I need is a filament which is really melting at 134 °C so the customer is earning a fully destroyed instrument if he is sterilizing it.
