If you have a pt100 (Ultimaker Original +) then you can send a mail to your local reseller and they should have one for you. Just remember to ask for one for UMO+ since the pt100 for UM2 are shorter (in cable length). Umo+ uses 1.5m cable and um2+ uses 1.2m cable.
A 1.2m can work but you will have yo leave out of the plastic cover loop that follows the bowden (if you installed it like the manual says.
To take itnout, you can heat the hotend to 150C and try to pull it grabbing it by the metal part (if you pull from the cable it will 99% fully break. Also you could push from the exit hole with your green screwdriver. As soon it goes out you must turn of the heat on the block 'asap' or the heater will keep pushing heat and without the sensor it can be dangerous to leave it on.
Other way to do it is. Take out the hotend, put a small drip of WD40 on the exit hole of the pt100 (on the heater block) and support it on a bench or somewhere fixed, then hit it with the green screw driver (fits through that hole) until it goes out.
So the pt100 is for the UMO+ Correct? Online it said it was not compatible with UMO. (as long as I order a longer cable)
I kept trying to remove the cable from the hot end, using the blunt end of a drill bit which fit nicely in the hole, and was able to get it out probably 5mm, then I tried to pull it out with a pair of pliers, but I kept bending the metal casing of the sensor, which seems to have damaged the wiring inside. Now it only works when I hold the wires in a certain position. I sent a few emails around to see who has the 1.5m long cable in stock, and I'm waiting for a response.
neotko 1,418
Edited by GuestLink to post
