You don't really belong here as this is not a UM and not Cura but whatever.
Did you try swapping cables between X axis and Z just to see if you can move the Z axis with the X driver and vice-versa? This will reduce the possible causes.
What do you mean I don't belong here? This is for Cura and Marlin. I posted this here because Marlin is the program I am using for the firmware.
I tested it the way you said and the Z axis from the left seems to rotate when I connect it to the X axis pins but when I put it back where both Z axis go, it doesn't rotate.
gr5 2,194
You don't really belong here as this is not a UM and not Cura but whatever.![:)](//content.invisioncic.com/ultimake/emoticons/5a33abdf6d109_1f60acopy.png)
