Hi, Neotko!
It seams that CURA crashes at the beginning. It doesn't write any log files at all.
Interesting is, that with CURA 2.3 Beta I had no problems.
Edited by GuestHi, Neotko!
I have the same issue today on 10.11.6.
Cura crashes immediately when attempting to launch the app after install.
I do have the crash log. Is there an appropriate way to share the file if it's useful to anyone?
Sure here do a dropbox or something link and I'm sure someone on @nallath team will take a look
Try renaming the folder where all the settings are kept ("~/Library/Application Support/cura/" I think it is now, or "~/.cura"). I think the final 2.3 version doesn't like it if you had one of the 2.3 betas installed.
I just installed 2.3 on a Windows 7 laptop and it just disappeared after showing the splash screen and I had one of the 2.3 betas installed. But after I renamed the settings folder and launched 2.3 again so it created a fresh settings folder it started properly.
Following works for me
Step 1: delete CURA.app from Programms
Step 2. empty Trash (!important!)
Step 3. Restart Mac OS X
Step 4. install CURA 2.3 again
A bit offtopic, but to fully clean Cura I recommend you use AppCleaner (free app and without ads or stuff)
http://freemacsoft.net/appcleaner/
Just remember to uncheck the dmg or you will have to download it again too
Thanks for the help!
I used AppCleaner to remove the previously installed version 2.1.3, emptied the trash, restarted and 2.3 installed fine.
Same here, it crashes on startup. I've deleted the old one and beta using AppCleaner (lost all my profiles :( and rebooted multiple times.
The strange thing is, it does run directly from the DMG, so it definitely has something to do with files that are still in place.
I can send the crash log to someone if that helps?
We're having the same sort of issue with v2.3.1 - the application crashes immediately if run.
I've tried using AppCleaner, deleting ~/.cura and ~/Library/Application Support/Cura etc without luck
Interestingly I've found that the program will run if you manually run /Applications/Cura.app/Contents/MacOS/cura from the Terminal. Running it this way outputs a lot of DEBUG and other logs to the terminal - nothing obvious that might explain the problem though.
Could you post the info from debug? It could help a lot @nallath and the other guys behind Cura to find the source of the problem.
Thanks!
This is the output from Cura when cura is run directly out of the App contents. Note that there is no /Users/ultimaker folder or user on this computer - this must be hardcoded in the app.
/Applications/Cura.app/Contents/MacOS/cura ; exit;
Adding QT5 plugin path: /Applications/Cura.app/Contents/Resources/plugins
Loaded plugin 3MFReader
Loaded plugin AutoSave
Loaded plugin ChangeLogPlugin
2016-11-28 12:08:53,481 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin ConsoleLogger
2016-11-28 12:08:53,498 - INFO - .../plugins/plugins/CuraEngineBackend/CuraEngineBackend.py (__init__ [40]): Found CuraEngine at: /Applications/Cura.app/Contents/MacOS/CuraEngine
2016-11-28 12:08:53,499 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin CuraEngineBackend
2016-11-28 12:08:53,504 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin CuraProfileReader
2016-11-28 12:08:53,510 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin CuraProfileWriter
2016-11-28 12:08:53,586 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Plugin Doodle3D uses an incompatible API version, ignoring
2016-11-28 12:08:53,591 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin 3MFWriter
2016-11-28 12:08:53,596 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin OBJReader
2016-11-28 12:08:53,601 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin OBJWriter
2016-11-28 12:08:53,607 - WARNING - .../plugins/plugins/FileHandlers/STLReader/STLReader.py ( [5]): Could not find numpy-stl, falling back to slower code.
2016-11-28 12:08:53,609 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin STLReader
2016-11-28 12:08:53,613 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin STLWriter
2016-11-28 12:08:53,620 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin FileLogger
2016-11-28 12:08:53,626 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin GCodeProfileReader
2016-11-28 12:08:53,631 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin GCodeWriter
2016-11-28 12:08:53,638 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin ImageReader
2016-11-28 12:08:53,667 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin LayerView
2016-11-28 12:08:53,673 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin LegacyProfileReader
2016-11-28 12:08:53,679 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin LocalFileOutputDevice
2016-11-28 12:08:53,686 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin MachineSettingsAction
2016-11-28 12:08:53,705 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin PerObjectSettingsTool
2016-11-28 12:08:53,713 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin PostProcessingPlugin
2016-11-28 12:08:53,731 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin RemovableDriveOutputDevice
2016-11-28 12:08:53,753 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin SliceInfoPlugin
2016-11-28 12:08:53,760 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin SolidView
2016-11-28 12:08:53,768 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin CameraTool
2016-11-28 12:08:53,779 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin MirrorTool
2016-11-28 12:08:53,795 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin RotateTool
2016-11-28 12:08:53,807 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin ScaleTool
2016-11-28 12:08:53,814 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin SelectionTool
2016-11-28 12:08:53,823 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin TranslateTool
2016-11-28 12:08:53,837 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin UltimakerMachineActions
2016-11-28 12:08:53,880 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin UM3NetworkPrinting
2016-11-28 12:08:53,898 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin UpdateChecker
2016-11-28 12:08:53,899 - INFO - .../plugins/plugins/UpdateChecker/UpdateChecker.py (run [28]): Checking for new version of cura
2016-11-28 12:08:53,938 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin USBPrinting
2016-11-28 12:08:53,957 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin VersionUpgrade21to22
2016-11-28 12:08:53,964 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin SimpleView
2016-11-28 12:08:53,970 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin WireframeView
2016-11-28 12:08:53,978 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin X3DReader
2016-11-28 12:08:53,995 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin XmlMaterialProfile
2016-11-28 12:08:54,003 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/PluginRegistry.py (loadPlugin [63]): Loaded plugin XRayView
2016-11-28 12:08:54,004 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Qt/QtApplication.py (__init__ [39]): Command line arguments: {'debug-mode': False, 'disable-textures': False, 'external-backend': False, 'file': []}
2016-11-28 12:08:54,030 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/VersionUpgradeManager.py (upgrade [98]): Looking for old configuration files to upgrade.
2016-11-28 12:09:00,118 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Backend/Backend.py (_logSocketState [165]): Socket state changed to Listening
2016-11-28 12:09:00,128 - INFO - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Backend/Backend.py (startEngine [55]): Started engine process: /Applications/Cura.app/Contents/MacOS/CuraEngine
2016-11-28 12:09:00,128 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Backend/Backend.py (_backendLog [88]): [backend] Calling engine with: ['/Applications/Cura.app/Contents/MacOS/CuraEngine', 'connect', '127.0.0.1:49674', '-j', '/Applications/Cura.app/Contents/MacOS/resources/definitions/fdmprinter.def.json', '']
2016-11-28 12:09:00,129 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Backend/Backend.py (_backendLog [88]): [backend]
2016-11-28 12:09:00,130 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Backend/Backend.py (_backendLog [88]): [backend] Cura_SteamEngine version DEV
2016-11-28 12:09:00,131 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Backend/Backend.py (_backendLog [88]): [backend] Copyright © 2014 David Braam
2016-11-28 12:09:00,136 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Backend/Backend.py (_backendLog [88]): [backend]
2016-11-28 12:09:00,136 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Backend/Backend.py (_backendLog [88]): [backend] This program is free software: you can redistribute it and/or modify
2016-11-28 12:09:00,136 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Backend/Backend.py (_backendLog [88]): [backend] it under the terms of the GNU Affero General Public License as published by
2016-11-28 12:09:00,137 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Backend/Backend.py (_backendLog [88]): [backend] the Free Software Foundation, either version 3 of the License, or
2016-11-28 12:09:00,137 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Backend/Backend.py (_backendLog [88]): [backend] (at your option) any later version.
2016-11-28 12:09:00,139 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Backend/Backend.py (_backendLog [88]): [backend]
2016-11-28 12:09:00,139 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Backend/Backend.py (_backendLog [88]): [backend] This program is distributed in the hope that it will be useful,
2016-11-28 12:09:00,139 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Backend/Backend.py (_backendLog [88]): [backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
2016-11-28 12:09:00,140 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Backend/Backend.py (_backendLog [88]): [backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
2016-11-28 12:09:00,140 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Backend/Backend.py (_logSocketState [165]): Socket state changed to Connected
2016-11-28 12:09:00,140 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Backend/Backend.py (_backendLog [88]): [backend] GNU Affero General Public License for more details.
2016-11-28 12:09:00,140 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Backend/Backend.py (_onSocketStateChanged [155]): Backend connected on port 49674
2016-11-28 12:09:00,141 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Backend/Backend.py (_backendLog [88]): [backend]
2016-11-28 12:09:00,146 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Backend/Backend.py (_backendLog [88]): [backend] You should have received a copy of the GNU Affero General Public License
2016-11-28 12:09:00,148 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Backend/Backend.py (_backendLog [88]): [backend] along with this program. If not, see .
2016-11-28 12:09:00,256 - DEBUG - .../plugins/plugins/MachineSettingsAction/MachineSettingsAction.py (_onContainerAdded [40]): Not attaching MachineSettingsAction to ultimaker3; Multi-extrusion printers are not supported
2016-11-28 12:09:00,509 - DEBUG - .../plugins/plugins/MachineSettingsAction/MachineSettingsAction.py (_onContainerAdded [40]): Not attaching MachineSettingsAction to ultimaker_original_dual; Multi-extrusion printers are not supported
2016-11-28 12:09:00,936 - DEBUG - .../plugins/plugins/MachineSettingsAction/MachineSettingsAction.py (_onContainerAdded [40]): Not attaching MachineSettingsAction to ultimaker3_extended; Multi-extrusion printers are not supported
2016-11-28 12:09:01,688 - DEBUG - .../plugins/plugins/MachineSettingsAction/MachineSettingsAction.py (_onContainerAdded [40]): Not attaching MachineSettingsAction to ultimaker2_extended_plus; Machines that use variants are not supported
2016-11-28 12:09:02,278 - DEBUG - .../plugins/plugins/MachineSettingsAction/MachineSettingsAction.py (_onContainerAdded [40]): Not attaching MachineSettingsAction to ultimaker2_plus; Machines that use variants are not supported
2016-11-28 12:09:08,761 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Settings/ContainerStack.py (deserialize [235]): While deserializing, we got the following container string: ultimaker3_extended_extruder_left #2_current_settings,empty_quality_changes,um3_aa0.4_PLA_Normal_Quality,ultimaker_pla_silver-metallic_ultimaker3_AA_0.4,ultimaker3_aa04,ultimaker3_extended_extruder_left,
2016-11-28 12:09:08,764 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Settings/ContainerStack.py (deserialize [235]): While deserializing, we got the following container string: ultimaker3_extended_extruder_right #2_current_settings,empty_quality_changes,um3_aa0.4_PLA_Normal_Quality,ultimaker_pla_white_ultimaker3_AA_0.4,ultimaker3_aa04,ultimaker3_extended_extruder_right,
2016-11-28 12:09:08,766 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Settings/ContainerStack.py (deserialize [235]): While deserializing, we got the following container string: Ultimaker 3 Extended_current_settings,empty_quality_changes,um3_global_Normal_Quality,empty_material,empty_variant,ultimaker3_extended,
2016-11-28 12:09:08,771 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Controller.py (setActiveView [80]): Setting active view to SolidView
2016-11-28 12:09:08,776 - WARNING - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/cura/Settings/ExtruderManager.py (getMachineExtruders [304]): Tried to get the extruder trains for machine Ultimaker 3 Extended, which doesn't exist.
2016-11-28 12:09:11,080 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Qt/Bindings/Theme.py (load [118]): Loading theme file: /Applications/Cura.app/Contents/MacOS/resources/themes/cura/theme.json
2016-11-28 12:09:11,250 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Qt/Bindings/Theme.py (load [118]): Loaded theme /Applications/Cura.app/Contents/MacOS/resources/themes/cura
QObject::connect: Parentheses expected, signal MainWindow::
qml: TableViewSelection: index out of range
2016-11-28 12:09:12,742 - DEBUG - .../plugins/plugins/UM3NetworkPrinting/DiscoverUM3Action.py (_createAdditionalComponentsView [133]): Creating additional ui components for UM3.
2016-11-28 12:09:12,841 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Mesh/MeshData.py (approximateConvexHull [305]): approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.046231985092163086 seconds. 121 input vertices. 121 output vertices.
2016-11-28 12:09:13,246 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Qt/GL/QtOpenGL.py (__init__ [19]): Initialized OpenGL subsystems.
2016-11-28 12:09:13,246 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Qt/GL/QtOpenGL.py (__init__ [19]): OpenGL Version: 2.1 ATI-1.42.15
2016-11-28 12:09:13,246 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Qt/GL/QtOpenGL.py (__init__ [19]): OpenGL Vendor: ATI Technologies Inc.
2016-11-28 12:09:13,246 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Qt/GL/QtOpenGL.py (__init__ [19]): OpenGL Renderer: AMD Radeon HD 6750M OpenGL Engine
2016-11-28 12:09:23,804 - DEBUG - .../plugins/plugins/AutoSave/AutoSave.py (_onTimeout [46]): Autosaving preferences, instances and profiles
And when the application is quit you get this:
2016-11-28 12:28:51,442 - DEBUG - /Users/ultimaker/build/2.3/build/inst/lib/python3.5/site-packages/UM/Qt/QtApplication.py (windowClosed [197]): Shutting down cura
2016-11-28 12:28:53,355 - DEBUG - .../plugins/plugins/CuraEngineBackend/CuraEngineBackend.py (_terminate [186]): Attempting to kill the engine process
2016-11-28 12:28:53,356 - DEBUG - .../plugins/plugins/CuraEngineBackend/CuraEngineBackend.py (_terminate [186]): Killing engine process
2016-11-28 12:28:53,356 - DEBUG - .../plugins/plugins/CuraEngineBackend/CuraEngineBackend.py (_terminate [186]): Engine process is killed. Received return code -15
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
This is the contents of the Apple crash report:
Process: Cura [2064]
Path: /Applications/Cura.app/Contents/MacOS/Cura
Identifier: org.pythonmac.unspecified.Cura
Version: ???
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Cura [2064]
User ID: 501
Date/Time: 2016-11-28 12:33:38.799 +1100
OS Version: Mac OS X 10.11.6 (15G1108)
Report Version: 11
Anonymous UUID: 26875764-30EB-902F-20F3-91C9FB73E04F
Time Awake Since Boot: 14000 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
abort() called
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff8b215f06 __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007fff8d3374ec pthread_kill + 90
2 libsystem_c.dylib 0x00007fff8ce006df abort + 129
3 Cura 0x0000000105ef74be Py_FatalError + 462
4 Cura 0x0000000105dff22e main + 3294
5 Cura 0x0000000105dfe544 start + 52
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000006 rcx: 0x00007fff59e02638 rdx: 0x0000000000000000
rdi: 0x000000000000160b rsi: 0x0000000000000006 rbp: 0x00007fff59e02660 rsp: 0x00007fff59e02638
r8: 0x00000000fffffffc r9: 0x00007fcec8f29970 r10: 0x0000000008000000 r11: 0x0000000000000206
r12: 0x00007fff7a1d1bd0 r13: 0x0000000106050878 r14: 0x00007fff7a2e2000 r15: 0x0000000000000002
rip: 0x00007fff8b215f06 rfl: 0x0000000000000206 cr2: 0x00007fff7a1cf008
Logical CPU: 0
Error Code: 0x02000148
Trap Number: 133
Binary Images:
0x105dfd000 - 0x105fcefff +Cura (???) /Applications/Cura.app/Contents/MacOS/Cura
0x1062cc000 - 0x1062cfff7 +zlib.cpython-35-darwin.so (???) /Applications/Cura.app/Contents/MacOS/lib/python3.5/zlib.cpython-35-darwin.so
0x7fff612c9000 - 0x7fff61300a47 dyld (360.22) /usr/lib/dyld
0x7fff892f6000 - 0x7fff892f9ffb libdyld.dylib (360.22) <25D28225-99AE-3A04-B98C-ACFF47D6D9B0> /usr/lib/system/libdyld.dylib
0x7fff89bce000 - 0x7fff89bceff7 libkeymgr.dylib (28) <8371CE54-5FDD-3CE9-B3DF-E98C761B6FE0> /usr/lib/system/libkeymgr.dylib
0x7fff8a3d9000 - 0x7fff8a744657 libobjc.A.dylib (680) /usr/lib/libobjc.A.dylib
0x7fff8a8f4000 - 0x7fff8ad6aff7 com.apple.CoreFoundation (6.9 - 1259) <51D1F34F-9FEC-3EF2-8382-2D13D75F845A> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff8b1ff000 - 0x7fff8b21dff7 libsystem_kernel.dylib (3248.60.11) /usr/lib/system/libsystem_kernel.dylib
0x7fff8b371000 - 0x7fff8b382ff7 libsystem_trace.dylib (201.10.3) /usr/lib/system/libsystem_trace.dylib
0x7fff8b3d8000 - 0x7fff8b3ddff7 libmacho.dylib (875.1) <318264FA-58F1-39D8-8285-1F6254EE410E> /usr/lib/system/libmacho.dylib
0x7fff8b7bb000 - 0x7fff8b7ccff7 libz.1.dylib (61.20.1) /usr/lib/libz.1.dylib
0x7fff8bbb7000 - 0x7fff8bbb8fff libsystem_secinit.dylib (20) <32B1A8C6-DC84-3F4F-B8CE-9A52B47C3E6B> /usr/lib/system/libsystem_secinit.dylib
0x7fff8c7ec000 - 0x7fff8c832ff7 libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib
0x7fff8cc5b000 - 0x7fff8cc5ffff libcache.dylib (75) <9548AAE9-2AB7-3525-9ECE-A2A7C4688447> /usr/lib/system/libcache.dylib
0x7fff8cc60000 - 0x7fff8cc63fff libsystem_sandbox.dylib (460.60.2) <2A68B39C-B786-3A05-87A2-56E688469FB8> /usr/lib/system/libsystem_sandbox.dylib
0x7fff8cda2000 - 0x7fff8ce2ffef libsystem_c.dylib (1082.60.1) <28733D22-553E-3CBC-8D2C-EDCEB46E46AF> /usr/lib/system/libsystem_c.dylib
0x7fff8d1ba000 - 0x7fff8d1d6ff7 libsystem_malloc.dylib (67.40.1) <5748E8B2-F81C-34C6-8B13-456213127678> /usr/lib/system/libsystem_malloc.dylib
0x7fff8d2be000 - 0x7fff8d2c9ff7 libcommonCrypto.dylib (60075.50.1) <93732261-34B4-3914-B7A2-90A81A182DBA> /usr/lib/system/libcommonCrypto.dylib
0x7fff8d2fb000 - 0x7fff8d303fff libsystem_networkextension.dylib (385.40.36) <66095DC7-6539-38F2-95EE-458F15F6D014> /usr/lib/system/libsystem_networkextension.dylib
0x7fff8d331000 - 0x7fff8d33aff7 libsystem_pthread.dylib (138.10.4) <3DD1EF4C-1D1B-3ABF-8CC6-B3B1CEEE9559> /usr/lib/system/libsystem_pthread.dylib
0x7fff8d6b3000 - 0x7fff8d6b5ff7 libsystem_configuration.dylib (802.40.13) <3DEB7DF9-6804-37E1-BC83-0166882FF0FF> /usr/lib/system/libsystem_configuration.dylib
0x7fff8d802000 - 0x7fff8d803ffb libremovefile.dylib (41) <552EF39E-14D7-363E-9059-4565AC2F894E> /usr/lib/system/libremovefile.dylib
0x7fff8e40f000 - 0x7fff8e43effb libsystem_m.dylib (3105) <08E1A4B2-6448-3DFE-A58C-ACC7335BE7E4> /usr/lib/system/libsystem_m.dylib
0x7fff8e7b6000 - 0x7fff8e7beffb libsystem_dnssd.dylib (625.60.4) <80189998-32B0-316C-B5C5-53857486713D> /usr/lib/system/libsystem_dnssd.dylib
0x7fff8e81a000 - 0x7fff8e822fef libsystem_platform.dylib (74.40.2) <29A905EF-6777-3C33-82B0-6C3A88C4BA15> /usr/lib/system/libsystem_platform.dylib
0x7fff8e9cd000 - 0x7fff8e9cfff7 libquarantine.dylib (80) <0F4169F0-0C84-3A25-B3AE-E47B3586D908> /usr/lib/system/libquarantine.dylib
0x7fff8ea45000 - 0x7fff8ea4dfff libcopyfile.dylib (127) /usr/lib/system/libcopyfile.dylib
0x7fff8f898000 - 0x7fff8f899fff libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff8f949000 - 0x7fff8f952ff3 libsystem_notify.dylib (150.40.1) /usr/lib/system/libsystem_notify.dylib
0x7fff8faa2000 - 0x7fff8fab9ff7 libsystem_asl.dylib (323.50.1) <41F8E11F-1BD0-3F1D-BA3A-AA1577ED98A9> /usr/lib/system/libsystem_asl.dylib
0x7fff8ff5d000 - 0x7fff8ff5effb libSystem.B.dylib (1226.10.1) <012548CD-614D-3AF0-B3B1-676F427D2CD6> /usr/lib/libSystem.B.dylib
0x7fff90b77000 - 0x7fff90b78fff libsystem_blocks.dylib (65) <1244D9D5-F6AA-35BB-B307-86851C24B8E5> /usr/lib/system/libsystem_blocks.dylib
0x7fff921cb000 - 0x7fff921f4fff libsystem_info.dylib (477.50.4) /usr/lib/system/libsystem_info.dylib
0x7fff92c41000 - 0x7fff92c6efff libdispatch.dylib (501.40.12) /usr/lib/system/libdispatch.dylib
0x7fff963ec000 - 0x7fff963eefff libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib
0x7fff9689e000 - 0x7fff96aabfff libicucore.A.dylib (551.51.4) <3899B146-3840-3D4A-8C4A-FE391D5D25C7> /usr/lib/libicucore.A.dylib
0x7fff9a29b000 - 0x7fff9a301ff7 libsystem_network.dylib (583.50.1) /usr/lib/system/libsystem_network.dylib
0x7fff9accd000 - 0x7fff9acd4ff7 libcompiler_rt.dylib (62) /usr/lib/system/libcompiler_rt.dylib
0x7fff9ae05000 - 0x7fff9ae2fff7 libc++abi.dylib (307.2) <922EFB36-0E9E-315B-8270-E81AC43472C0> /usr/lib/libc++abi.dylib
0x7fff9ae5e000 - 0x7fff9ae63ff3 libunwind.dylib (35.3) /usr/lib/system/libunwind.dylib
0x7fff9b54f000 - 0x7fff9b54fff7 libunc.dylib (29) /usr/lib/system/libunc.dylib
0x7fff9b591000 - 0x7fff9b5a8ff7 libsystem_coretls.dylib (83.40.5) /usr/lib/system/libsystem_coretls.dylib
0x7fff9c6c2000 - 0x7fff9c739feb libcorecrypto.dylib (335.50.1) /usr/lib/system/libcorecrypto.dylib
0x7fff9c7f5000 - 0x7fff9c7f5ff7 liblaunch.dylib (765.50.8) <834ED605-5114-3641-AA4D-ECF31B801C50> /usr/lib/system/liblaunch.dylib
0x7fff9d885000 - 0x7fff9d8d8ff7 libc++.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc++.1.dylib
0x7fff9e60a000 - 0x7fff9e633ff7 libxpc.dylib (765.50.8) <54D1328E-054E-3DAA-89E2-375722F9D18F> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 5490
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=107.6M resident=0K(0%) swapped_out_or_unallocated=107.6M(100%)
Writable regions: Total=49.0M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=49.0M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Activity Tracing 2048K 2
Kernel Alloc Once 4K 2
MALLOC 36.3M 10
MALLOC guard page 16K 4
MALLOC_LARGE (reserved) 384K 3 reserved VM address space (unallocated)
Process Corpse Info 2048K 2
STACK GUARD 56.0M 2
Stack 8192K 2
VM_ALLOCATE 4K 2
__DATA 3400K 48
__LINKEDIT 91.6M 5
__TEXT 15.9M 47
__UNICODE 552K 2
shared memory 8K 3
TOTAL 216.1M 120
TOTAL, minus reserved VM space 215.8M 120
Model: iMac12,1, BootROM IM121.0047.B23, 4 processors, Intel Core i5, 2.5 GHz, 32 GB, SMC 1.71f25
Graphics: AMD Radeon HD 6750M, AMD Radeon HD 6750M, PCIe, 512 MB
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1333 MHz, 0x0000, 0x4D41432D3136303020202020202020202020
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1333 MHz, 0x0000, 0x4D41432D3136303020202020202020202020
Memory Module: BANK 0/DIMM1, 8 GB, DDR3, 1333 MHz, 0x0000, 0x4D41432D3136303020202020202020202020
Memory Module: BANK 1/DIMM1, 8 GB, DDR3, 1333 MHz, 0x0000, 0x4D41432D3136303020202020202020202020
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x9A), Atheros 9380: 4.0.74.0-P2P
Bluetooth: Version 4.4.6f1 17910, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Serial ATA Device: ST3500418AS, 500.11 GB
Serial ATA Device: OPTIARC DVD RW AD-5690H
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: USB 2.0 Hub [MTT]
USB Device: Mass Storage
USB Device: IR Receiver
USB Device: Card Reader
USB Device: FaceTime HD Camera (Built-in)
USB Device: Hub
USB Device: Keyboard Hub
USB Device: Apple Keyboard
USB Device: BRCM2046 Hub
USB Device: Bluetooth USB Host Controller
Thunderbolt Bus: iMac, Apple Inc., 25.1
Had the exact same problem on my iMac, installing Cura 2.3.1.
After I pasted it in the applications folder it crashes.
I solved it by making a new map in applications and pasted the Cura file there!
That works fine...
Still don't know why the normal routine doesn't work, but that's for the pro's to find out
Have a nice Day! gr Bas
Well this is bizarre - following on from Makairsjop's post I renamed the Cura.app file in Applications and ran it from the Applications folder (rather than the taskbar menu) and this time it worked. Renamed it back and it still works... Deleted and reinstall and it still works!... No idea why this would be any different to only deleting and reinstalling, but something obviously has happened to fix the crash.
neotko 1,415
Maybe you can share a file with the full log file. On my MBP retina with latest macOS Sierra works quite ok.
