Blender STL file is extremely small
Posted · Blender STL file is extremely small
I have a friend whose working on a design he wants me to 3D print
However the exported file he has sent me shows up very, very small in Cura
He's using Blender, something I don't know a thing about.
Any ideas on how I can guide him to a successful export I can use?
    I don't know anything about Blender either, but is there no way to set physical dimensions?
    Or, if it would be a sort of "freehand sculpture", without any reference to dimensions, maybe he could create a little cube next to it, and give that cube exact physical dimensions?
    Since people can design planes exactly to scale in Blender, something like this should be possible.
    • 2 weeks later...
    Posted (edited) · Blender STL file is extremely small
    Set the "Scale" in the STL export window to 1000 for mm or 100 for cm. Blender by default doesn't use units, but one unit is usually interpreted as 1 m, but imported in most other software as cm or mm (if using units options of "None" or "Metric").
