Foehnsturm Dual Extruder Approach
Posted · Foehnsturm Dual Extruder Approach
Could someone enlighten me if possible, Before my UM2 goes, could I use the two Bondtech's I have (1fitted) (1spare) with this mod, I believe TinkerGnome I think is supplying the firmware... Just checking before I let the Printer go. if it is compatible I'm keeping it......
    Thanks for the Reply
    That said, I have 2 Bondtech's - 2 3D Solex matchless blocks and nozzles and a spare Bowden.. I also have Spare Fans (3) and a Spare Fan Shroud??
    All I would need then is another Heater 35w and a temps Probe.
    Correct???
    Yes I have the alloy parts as well, also the 3 plastic parts which I guess you don't need.... looks like I'm good to go. When the mod is available I'm interested?.. thanks for the replies
