Hello. when I insert the material and from the menu where you select it, I do not have the opportunity to do so because the selection of the material, alone, jump to the next page without giving me time to select the material.
Are you using UM materials? Then perhaps the material might be auto selected due to the NFC chip reading .
1
Yes, im using UM material.
Then it's probably the NFC auto selection
Ok. Thx guys.
The NFC chip in the holder can read / detect what material you place on the reel holder. Therefor, it automatically moves forward in the menu and you don't have to make a selection yourself
Enjoy your new Ultimaker 3!
Ok m8.
ultiarjan 1,209
Can you try to explain a little bit more? I don't really understand what your problem is.
