I had some similar random shifting.
https://ultimaker.com/en/community/22908-shifted-print
But it sounds like you checked EVERYTHING already.
I think my problem was a sticky rod, but you wipe your down every week, so that can't be it.
I took the internal motor covers (white sheet metal parts) out of the printer to let the motor "breathe" a little easier.
For long prints, I also aim a desk fan at the electronics underneath printer.
Any chance it could be a slicer problem. I doubt it, but you have ruled out a lot of other causes.
SandervG 1,522
Hi @Yoter, thank you for your post. Sounds like you have already done quite some troubleshooting!
Do you have a photo of what such a layer shift looks like in your print?
If it is a very abrupt shift, it could be that one of your end stops is triggering a signal.
If it is slightly more gradually, I would look into your pulleys.
Alternatively, it could be that a motor or stepper driver is overheating, but at that speed, and if it also happens around the first layers, that sounds pretty unlikely.
To rule out pulleys, when you are printing, can you prevent your printhead from moving around? Like stop it in its path?
It should be quite hard to do, and most likely should start skipping steps than your pulley loosing grip / slipping.
I don't think it would be silly to unplug the end stops during a print after it zeroed. You may want to stick around when the print finishes though. But worst case, it will try to move across the frame for like 5 seconds, causing some noise, and then will give up and stop. You could also try flipping the end stops, see if it changes the behaviour of your layer shift.
Alternatively, you could also try to change your X and Y motor.
In any case, some pictures would probably help.
