Anyone retrofitted a UM2 print head on the UM original machine?
Posted (edited) · Anyone retrofitted a UM2 print head on the UM original machine?
I just received the UM2+ upgrade and realize that I'm going to be removing the original UM2 print head for the UM2+ head.   I also happen to have a thoroughly hacked/modded UM original-original machine.
Has anyone come up with a hack/mod to refit the UM2 head into the UM original-original Machine?   Perhaps  a printed replacement of the wood enclosure which allows the larger UM original rods, but permits the UM2 heater/head assembly to screw on?
Thoughts?
*B
    @neotko has a nice document for a UMO upgrade using the UM2 head
    I've thought about re-using the UM2 head since I upgraded to UM2+   I have an Ultimaker Original but there's some question about how to make the existing electronics work (sounds hard) or replace the UMO with UM2 main board (again, pricey).
    Also, I know I was looking around at replacing the guts of the UM2 print head with the latest stuff (spacer, teflon, etc)
    @neotko, he does not have a UMO+     Just a UMO like me
    The question is about re-using the UM2 head in the UMO
    The article you linked refers to using a UM2+ on a UMO+
    Posted · Anyone retrofitted a UM2 print head on the UM original machine?
    The YouMagine link is for the UMO+ to UM2+ extruder
    Read the description @meduza uses on youmagine and the post linked
    Quote from @meduza:
    "Not necessarily, we have done a upgrade with the UM2 head on a UMO with the original electronics.
    You need to supply the electronics board with 24V, change out the linear regulator that supplies 12V to the arduino to a switched type that can take the higher voltage without getting too hot, and add a PT100 amplifier (E3D sells this one: http://e3d-online.com/PT100-Amplifier-Board) between the board and the PT100 sensor from the printhead."
    "It should even be possible to use this to upgrade a non-plus UMO if you also get a PT100 amplifier board."
    Guys:
    Neither of you really answered my question. I have an original UM. One from the very first shipment ever made -- when UM was made in the founder's apartment.
    It has larger diameter rods than the UM2.
    I am looking for a physical adapter that will be a new head carrier to contain the bearings from the UM original (NOT the UMO+) and carry the UM2 "Print Head" (NOT the UM2 extruder), or will adapt the UM2 heater/fan/nozzle components to bolt onto the bottom of the existing UMO head carrier (with the UMO heater/fan/nozzle components removed).
    I guess no one came up with such a scenario? I'll have to design one myself.
    *B
    I have no idea of the parts the original original original version had. If you share pictures and specs maybe we can give you a hand.
    Ah, you still have a _very old_ UMO with the 8mm rods (it was changed a long time ago, long before the UMO+)...
    Instead of retrofitting those bearings to a UM2 head i would suggest to get a pair of the newer 6mm rods and using the bearings from the UM2 print head instead, it makes the whole gantry lighter and nicer.
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 14 replies
