How do I change material temperature setting?
Posted · How do I change material temperature setting?
I suppose that's because the 99% of the users don't reuse the gcode for other materials. And the truth is that every material needs more settings than just temp/fan.
If they concluded this (I'm just guessing) shouldn't make sense to just do the same on um2/um2+ and keep moving forward?
