Top Layers and Bottom Layers (or Top Thickness / Bottom Thickness) is your friend.
Setting 0 here is the same as unchecking the Solid infill ... in 14.x
Any number > 0 gives you this number (height) of solid layers (Bottom/Top thickness in 14.x)
Thank you Bernd...Either I didn't understand or the problem I have is not the one I believe !
My part has a wall and as you can see on the picture the wall is not filled...Not a printer issue as the slicer is showing it hollow ?!
berndjm 15
