Thank you tinkergnome for the welcome to the forum and for the redirect. It is exactly what I needed.
I searched the forums but did not find the posting you sent me too. It is good to know that I wasn't missing something obvious in the Cura profile settings. It is also good to know that my decision to go for an open source solution was the right one. I have only had my Ultimaker 3 for 72 hours, and am happy with what I am able to do. I expect I will be pushing the limits for small models so will likely be back for more advice and hopefully will have something to share as well.
Thanks again
1
tinkergnome 927
Welcome to the forum, @farmerritchie
AFAIK this option is deactivated in the machine settings for all devices with more than one extruder train. If you use only one nozzle for your prints, you can enable the "Print Sequence" setting by manually editing the machine definition file.
See this topic.
