I have issues with the brim printing too close to the object and sticking to the bottom layer. Anyone else with this, is there any setting to print brim x mm from object?
Thanks! Reported it at: https://github.com/Ultimaker/Cura/issues/1166
ghostkeeper 105
It still tries to create a brim on the outside of the inner pieces of the B. That is expected.
Why it then seems to create the brim from both sides is a bit weird though.
- 1
lol - that's the whole point of brim. If it doesn't stick to the part then the part is more likely to fall off. But definitely you can do this. It's called "skirt". So just turn off brim and you will get a skirt instead which is like brim but is not touching the part.
thopiekar 46
Thanks you for the report. I'll forward it to our developers.
Is your model uploaded anywhere, so we could reproduce it?
Thanks again!
