Well if you believe what Adafruit says on his video
Minute 18:50secs
They say 'it works out of the box' with 1.75mm
Ofc they print a few small lines
So, can it print? Depends on what you define as 'print'. If you just want to extrude material, without control or snapping the filament due the extruder is designed for 2.85, then sure, even spaghetti can work 'out of the box'.
So for real prints? No atm. For adafruit boxes, maybe? No...
Dim3nsioneer 551
No, you can't (atm) as the cores are 2.85mm only. However, it's an Ultimaker so a community member will find a way, I'm sure...
Edited by GuestLink to post
