The other thing I found really useful for UM3 adhesion, I think because of the increased fan power, was using the glue stick and a wet paper towel to have a very thin wash of glue on the areas of the bed I was printing on. I haven't attempted trying hairy spray instead of the glue yet; I'm having really excellent results with the glue on everything from 1 hour prints to 44 hour prints.
Thanks for the tip, Erin. I tried it out last night, and it worked great... for the PVA and PLA (if I'm ever printing in those materials, your tip will be a lifesaver). ABS was a different matter—the parts would get about 12 layers in, and then pop off the buildplate. :/ Is there any way to make the brim bond better to the print? Or just a way to make the ABS stick better?
And if there isn't, then how could you get the Buildtak to work? IRobertI, any ideas?
fbrc8-erin 283
Hi, RayvenMaker,
I haven't tried BuildTak with the UM3 yet, but there were a couple of other things I found useful for UM3 adhesion. The capacitive sensor board on the underside of the printhead is fairly sensitive. I found my results improved after I wiped the board down with alcohol and a paper towel. You can see it here in this photo:
